HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Astro
Fuel System
Fuel Pressure Regulator
Location
SPONSORED LINKS
1999 Chevy Astro FUEL
STEVENKING101
MEMBER
1999 CHEVROLET ASTRO
1999 Chevy Astro 6 cyl Two Wheel Drive Automatic
WHERE IS THE FUEL PREASURE REGULATOR
Saturday, January 2nd, 2010 AT 10:29 PM
MECHANIC
If its a vortec engine 4.3 its under the upper plenum
SPONSORED LINKS
Saturday, January 2nd, 2010 AT 10:35 PM
STEVENKING101
MEMBER
HOW DO I CHANGE IT
Saturday, January 2nd, 2010 AT 10:39 PM
MECHANIC
You need a repair manual there's special instructions that you have to follow, its under the upper plenum-
Saturday, January 2nd, 2010 AT 11:25 PM
Please
login
or
register
to post a reply.
Related Fuel Pressure Regulator Location Content
2003 Chevy Astro
Engine Performance Problem 2003 Chevy Astro 6 Cyl All Wheel Drive Automatic Where Is The Fuel Pressure Regulator Located, Have Looked...
Asked by
Apugh
1 ANSWER
2003
CHEVROLET ASTRO
I Have A 4.3l V6 And I Am Replacing The Fuel Pressure Regulator Which Is Supposed To Have A Vacuum Hooked To It. Mine However Was Missing...
Asked by
gmbam
1 ANSWER
1 IMAGE
1996
CHEVROLET ASTRO
2001 Chevrolet Astro Fule Pressure Regulator
Where Is The Fuel Pressure Regulator On 2001 Astro Yan
Asked by
bigal 1966
2001
CHEVROLET ASTRO
1996 Chevy Astro 1996 Astro Fuel Distribution Issues
1996 Astro Van. Currently Will Start After 12-20 Bumps Of The Ignition. Will Not Start With A Constant Crank Of The Ignition. Once It...
Asked by
brian1911
1996
CHEVROLET ASTRO
1995 Chevy Astro Fuel Supply
Engine Mechanical Problem 1995 Chevy Astro 6 Cyl Two Wheel Drive Automatic A Friend Of Mine Has A 95 Chevy Astro Taht Will Not Start...
Asked by
trimmer1253
1995
CHEVROLET ASTRO
VIEW MORE
SPONSORED LINKS
Fuel Pump Pressure Test
Fuel Pump Replacement
Check Engine Light Safe to Drive?
Online car repair manuals
