1991 Chevy Astro fuel pump replaced but no fuel to filter
ONTHE GROUND
  • 1991 CHEVROLET ASTRO
Engine Performance problem
1991 Chevy Astro 6 cyl Two Wheel Drive Automatic 100, + miles
There is no fuel reaching the fuel filter. Took line off and there is no gas. New pump and it comes on. Is there a fuel pressure regulator above the take inline or something else to look at?
Wednesday, December 31st, 2008 AT 8:47 AM
  • 108,443 POSTS
If you hear the pump running, you should be getting fuel. If it's not turning on, check the fuel pump relay under the hood in the relay box.
Friday, January 2nd, 2009 AT 1:04 PM
ONTHE GROUND
Replaced relay first, then filter then the pump. We droped the tank again and took the wire off as well. Reconnected the electronic connection and added more gas after. Started up fine.
Saturday, January 3rd, 2009 AT 6:51 AM
