ABS, traction control and 4X4 high lights are on?
JIR121653
  • 2005 FORD EXPLORER
  • V8
  • 4WD
  • 20,000 MILES
So, I have this Ford explorer and like a week ago all these three lights turned on I’m a just trying to do my own repairs. It’s kind of difficult because I really don’t know much about mechanical work but I’m not willing to give my hard-earned money to one more mechanic so that my car can stay the same or worse. I just need some direction on what it possibly could be?
Monday, February 13th, 2023 AT 8:49 PM
  • 108,443 POSTS
If the lights came on at the same time, chances are you have a faulty wheel speed sensor. That is the most common cause of all of the lights to turn on.
You have two ways to test this. First, if you have a live data scan tool, you can watch the wheel speed at each wheel and determine the one that is off. Or you can do it with a voltmeter or multimeter.
Take a look through this link and let me know if you are comfortable performing it:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
If you do and find an issue, here is a link to help replace one:
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Tuesday, February 14th, 2023 AT 11:35 AM
