1999 Ford Explorer Seat belt alarm?
CHICKENLADY
  • 1999 FORD EXPLORER
Computer problem
1999 Ford Explorer V8 All Wheel Drive Automatic
When I start the car, the seat belt safety alarm will sound off 5 "dings" pause and do this 5 times, and if we drive a distance it will sound again, 5 dings, 5 times. Any idea what it is trying to tell us?
Monday, July 27th, 2009 AT 12:14 PM
  • 108,443 POSTS
It is trying to tell the driver to fasten his seat belt. If it is, the switch in the reciever must be bad or there is a poor connection in the wiring to the receiver. If you follow the receiver down, you will see wiring for the alarm. Make sure it isn't damaged or disconnected at any point.
Tuesday, July 28th, 2009 AT 11:55 PM
CHICKENLADY
Could it be anything else other than seat belt? When I buckle the belt the light goes off in the dash, but the alarm keeps sounding.
Could it be a code of some sort?
Wednesday, July 29th, 2009 AT 7:22 AM
  • 108,443 POSTS
If the light goes out, the only other thing I would recommend having checked is the body control module (BCM). It requires special test equipment.
Wednesday, July 29th, 2009 AT 11:52 AM
