Motor not starting up
KHLOW2008
  • 41,814 POSTS
Check for a poor ground coonnection from battery to transmission.
Saturday, April 29th, 2017 AT 2:10 PM (Merged)
BASABROY
  • 2004 NISSAN SENTRA
  • 1.8L
  • 4 CYL
  • FWD
  • 73,000 MILES
I recently changed Crankshaft and Camshaft sensor. But still the starting problem exist.
When I start first time in the morning it starts at the first attempt. If I again start it after 1 hr or so it will start at the second attempt. After keeping it parked for 2/3 hours, it will again start at the first attempt.
What could be the issue?
Saturday, April 29th, 2017 AT 2:11 PM (Merged)
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure with a gauge auto parts rent it
BASABROY
Hi Hmac300,
Thanks a lot for your quick reply.
Now your reply sends shiver down my spine:(
How much could be expected repair cost if there's an issue with the fuel pressure? I live in Houston, Texas.
HMAC300
  • 48,601 POSTS
If it's the pump about $500 but it may not be that. That is why you have to scan for codes and check pressure. It cold be a regulator or something else all together.
