1999 Volkswagen Passat FAN STOPPED WORKING
DPATEL1682
  • 1999 VOLKSWAGEN PASSAT
  • 6 CYL
  • FWD
  • 175,000 MILES
All of suddend my car fan stopped working. Any suggestions?
Thanks a lot for all your help!
Saturday, October 23rd, 2010 AT 4:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Check fuses and cooling fan relays
Saturday, October 23rd, 2010 AT 9:16 PM
DPATEL1682
Do you have a fuze diagram? Also, how to check the relay?
Thanks
Tuesday, October 26th, 2010 AT 5:48 PM
BLUELIGHTNIN6
  • 16,542 POSTS
It will be 2 fuses in the auxiliary fuse panel ( under left side of dash) , a 5 amp and a 30 amp, I do not have their specific placement so may have to check them all in that panel.the relays will be there as well.. to learn how to check a relay follow this link..https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
Tuesday, October 26th, 2010 AT 8:34 PM
DPATEL1682
I checked all the Fuze and it works fine. I will look into Relay and test it. Yesterday when I tried to push the AC button, it came on and I can feel the cool air coming but not in the regular force when fan was acutally spinning. But after a minute, it went off.
Wednesday, October 27th, 2010 AT 9:48 AM
KHLOW2008
  • 41,814 POSTS
Hi dpatel1682,
Do you mean the blower fan that is not working?
Symptom indicates the fan motor is bad and would work intermittently.
Turn A/C on and bang the blower housing with your hands. If the fan starts working, the blower fan motor is bad and has to be replaced to rectify.
Sunday, October 31st, 2010 AT 3:43 AM
Related General Content
