2002 Volkswagen Jetta Engine won't start
JEREMY1234
  • 2002 VOLKSWAGEN JETTA
  • 4 CYL
  • 60,000 MILES
Car cranks but will not start where do I start to fix my problem
Sunday, October 31st, 2010 AT 5:10 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Tuesday, December 20th, 2016 AT 11:52 AM
JEREMY1234
Ok I sprayed the car woth ether bc its a diesel and it fired of but died very quickly do you know if there is a fuel pump in the tank? I kinda know there is something on the front of the motor that is tied into the timing chain>
Check the glow plugs, air in the system, fuel filters, injection pump and yes it has a fuel pump in the tank
JEREMY1234
Ok so when you turn the key forward it should pump fuel through the line goin to the filter right? If it is a problem with the in tank pump ow do I determine if its the pump or a relay
