Electrical problem
2001 Volkswagen Jetta 4 cyl Two Wheel Drive Automatic
We don’t have pulsation went we put the switch
The fuel pump doesn’t activate
Tuesday, July 28th, 2009 AT 6:31 PM
MECHANIC
Power the fuel pump directly from the battery-no pressure its defective.
SPONSORED LINKS
Tuesday, December 20th, 2016 AT 11:30 AM
LUIS R DELGADO
MEMBER
Do you have a phone #
I can talk to you and explain my situation
MECHANIC
We don't have pulsation went we put the switch
What switch are we talking about here-Is it the ignition switch?
If so start checking the fuse no. 28 and fuel pump relay
LUIS R DELGADO
MEMBER
We check the relay pump all the voltage all ground
Everything is working lake the diagram said
Is a cable violet and white on the relay we put a taster light
On ground and to this cable violet and white and the fuel pump star working
But the car don't start
Tuesday, December 20th, 2016 AT 11:31 AM
MECHANIC
Are you getting injection pulses from the injectors?
SPONSORED LINKS
LUIS R DELGADO
MEMBER
No pulsation and no spark
LUIS R DELGADO
MEMBER
# 28-43-32-34 dosnt have power
LUIS R DELGADO
MEMBER
Are you there I need to now this to night
please
MECHANIC
Check fuse no. 163 50amp and the power supply relay
