1999 Volkswagen Jetta won't start
RTTACONET
  • 1999 VOLKSWAGEN JETTA
Electrical problem
1999 Volkswagen Jetta 6 cyl Front Wheel Drive 100, 00 miles
I pulled into a parking lot the other night and shut off the car. I realized the windows were open and went to turn the car back on to close them and the car wouldn't start. I still have lights and the radio works. What can it be. I checked the fuses located near the drivers side leg area and the fuses over the battery. The battery also was recharged, not the battery. Are there any other fuse boxes?
Wednesday, July 9th, 2008 AT 7:38 PM
2CARPRO JACK
  • 11,533 POSTS
When you say wont start. Wont turn over or turns over and wont run? If it wont turn over use a test light to se if you are getting power to the small wire on the starter, if it turns and wont run, check for spark and fuel pressure
Tuesday, December 20th, 2016 AT 11:49 AM
