You might check your information its a Vin-K V-series with a 5.7 liter engine and MT. Shows in Chilton's Full size trucks manual 88-89. The flashing of the check engine light was on some times, then off for short periods of time not like a constant flash. "Flashing". Thank you for not even giving any information that you might think the problem may be, and pointing out small technicalities. But, thanks, I will go to O'Reilly's auto parts and they can probably find the answer.
SPONSORED LINKS
Friday, January 3rd, 2014 AT 9:26 PM
