1999 Toyota Corolla CEL is on for months
PETERWQW2002
  • 1999 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 71,400 MILES
CEL is on since April. DTC is P0441/P0446. I went to auto shop. VSV (vacuum switch valve) under front hood was changed. Charcoal canister was replaced in rear end underneath. New gas cap was put on. Smoking engine was used to test leak of fuel. Unfortunately, all thes seem not working with my car. The check engine light is always back again and again following a couple of miles driving after each repair. The DTC is P0446 now.
Any suggestion or advice? Thank you!
Tuesday, August 19th, 2008 AT 3:00 PM
MERLIN2021
  • 17,250 POSTS
Get your money back, the shop should have looked at the Tecnical service Bulliten!
Go to Toyota, get your free ECM by 80,000 miles! Go NOW!
This tech bulliten comes right from Toyota, You need a new computer.
FALSE DTC P0446 - REPLACE ECM -1999 Toyota Corolla CE
Tuesday, August 19th, 2008 AT 3:11 PM
PETERWQW2002
  • 9 POSTS
Thanks for answering my question. Do you mean that I am qualified to get a free ECM from Toyota right now (mile 71400)?
Tuesday, August 19th, 2008 AT 3:50 PM
MERLIN2021
  • 17,250 POSTS
80,000 miles and 96 months. So I think so! 8 years? I don't know when you bought it, but if you can prove when the proble started was before the 8 year cut off, then yes. But in either case, this IS your problem, maybe the shop that screwed up the diagnosis will pay for it!
Tuesday, August 19th, 2008 AT 4:06 PM
PETERWQW2002
  • 9 POSTS
I appreciate your prompt response to my question. Thank yuo very much!
Tuesday, August 19th, 2008 AT 4:11 PM
MERLIN2021
  • 17,250 POSTS
Your welcome.
Tuesday, August 19th, 2008 AT 4:15 PM
PETERWQW2002
  • 9 POSTS
I try to give you positive point to appeciate your work but I am told by computer that I am not allowed to give points more than I have (0.2). Sorry.
Tuesday, August 19th, 2008 AT 4:27 PM
PETERWQW2002
  • 9 POSTS
To Merlin2021:
I checked the part number of Engine Control Module (ECM) in my car. It ends in a "0" and needs to be replaced. This car was 1999 Corolla and I bought it in 2002 (a used car sold by car dealer). The ECL problem developed in April this year. Based on warranty requirement (96 months or 80K miles from vehicle's in-service date), should I contact Toyota dealer for reapir coverage? Thank you for any opinion !
Wednesday, August 20th, 2008 AT 6:56 PM
MERLIN2021
  • 17,250 POSTS
My opinion is if you bought it from a Toyota dealer, return there and ask.
Thursday, August 21st, 2008 AT 4:09 PM
PETERWQW2002
  • 9 POSTS
Thanks a lot for comment. I will try.
Friday, August 22nd, 2008 AT 9:43 AM
