1982 Toyota Corolla
MRMIKE59
  • 1982 TOYOTA COROLLA
  • 4 CYL
  • 54,000 MILES
Is there anything special I should prior to starting the engine, the car has been parked for six months?
Friday, December 11th, 2009 AT 10:52 AM
  • 31,937 POSTS
Hi there,
After 6 months, all I would be doing is pulling the plugs add a small amount of oil to each Cly and give it a crank over with the plugs out, this will lube up the bores so you don't damage a bore with a dry start, this will also get up oil pressure in the system so all bearings will be well lubricated.
Mark (mhpautos)
Friday, December 11th, 2009 AT 3:10 PM
