Door Locks not working when pushed to open only the drivers door opens?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,690 POSTS
If all of the door actuators went out at the same time, I would replace the BCM. Please let us know how it goes.
Sunday, June 25th, 2023 AT 11:46 AM
VISHWA
Thank you so much for responding Ken. I appreciate your help here. Except driver side door, all other passengers' doors (including right side front door) are not getting unlocked either with fob or main side switch from driver door. Can you please point me where I can buy BCM for Camry 2011 and do I need to take help of mechanic or is it DIY? After getting a new one, do we need to program it? I heard BCM is very costly. Again, thanks a ton for helping me here.
Sunday, June 25th, 2023 AT 4:26 PM
KEN L
  • 47,690 POSTS
They are not too bad money wise, just search eBay or google to find a preprogrammed unit and you should be all set. It is a DIY project for sure.
Monday, June 26th, 2023 AT 12:00 PM
GURU1985
  • 5 POSTS
Hi Vishwa, I am also in the same boat about Camry 2011, 3 doors not getting unlocked.
Tuesday, June 27th, 2023 AT 5:34 AM
KEN L
  • 47,690 POSTS
Sorry, this is a thread for a 2004 car. Please post your new question here, you must be logged in. We need to start a new thread.
Cheers, Ken
Tuesday, June 27th, 2023 AT 10:06 AM
VISHWA
@guru1985 - I was able fix the door lock issue. Did you resolve your car door lock issue?
Monday, August 21st, 2023 AT 6:14 PM
SHIVAREDDY
@Vishwa - can you please tell me how did you fix this? Did you replace BCM? If so how did you find the exact /correct BCM online for the options that your car has? Online I see many different BCM's for same 2011 camry so unable to confirm which one to buy?
Tuesday, September 17th, 2024 AT 7:49 PM
SHIVAREDDY
Hi @Vishwa, can you please let me know how did you find exact part for 2011 camry, online I see many different BCM for same year camry, so unable to identify which one to buy
Tuesday, September 17th, 2024 AT 7:52 PM
KEN L
  • 47,690 POSTS
This post is for a 2004 toyota camry not a 2011. Please post your new question here, you must be logged in.
Cheers, Ken
Wednesday, October 2nd, 2024 AT 5:52 PM
