1992 Toyota Camry starting problem
KEVINPLOUFFE
  • 1992 TOYOTA CAMRY
1992 Toyota camry 2.2 litre 237,000 kms. I just bought this camry, and one day I started it and before I could drive away It stopped on its own. I tried starting it and it turmed over but wouldn't fire up. It has a full tank of gas, it has spark to the spark plug on the left(the only one I checked). The fuel pump seems to run, Could it be the fuel filter or is there a more common problem?
Monday, September 24th, 2007 AT 12:01 AM
Next time it stalls out immediately check for sparky and fuelly-one of this is not gonna show up. If both shows up, remove the air tube from TB inject fuel in it, if it fires up-
Check the actual fuel pressure-good pressure, crank engine over while listening to the injector/s-is it clicking-no clicking-check injector wire connector red/black-turn key to On-do you have power?
Okay we stop here till you come back.
Monday, September 24th, 2007 AT 3:42 AM
BUZZSAW
  • 1,198 POSTS
Okay we stop here till you come back.[/Quote:40ee0b1194]
mark the distributor, only has 1 bolt, check the coil for burn marks, 1 thing to check, insted of pulling dist use a mirror to check, if its got burn marks replace coil and wires and plugs if not new ( use toyota parts )
Tuesday, September 25th, 2007 AT 1:44 AM
Take over this thread-you're doing good maybe if you knock this out I'll recommend Tech3-Holler when you need me you hea!!!
http://www.2carpros.com/forum/automotive_pictures/12900_icon77_5.gif
Tuesday, September 25th, 2007 AT 1:55 AM
