1992 Toyota Camry No start only when hot.
GRSMNKY
  • 1992 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 90,000 MILES
Car runs fine, drives fine, no codes, idle normal. Starts fine in the morning every time. After the car has been driven and I try to start it again while it is still warm, it will crank but will not start unless I hold the gas pedal all the way down as I turn the key. This way it always starts from the first crank every single time. Any ideas? I have replaced the plugs and wires because it was due to a tune-up anyway which did not change the condition. Thanks in advance. Alex.
Wednesday, April 1st, 2009 AT 9:35 PM
Check the idle air control valve, airflow meter and throttle position sensor to include the fuel pressure
Wednesday, April 1st, 2009 AT 10:50 PM
WILLIAM OLIVER
  • 25 POSTS
Ck distributor coil inside distributor see if is cracked. If it is replace the coil. See if this solve your problem
Thursday, April 2nd, 2009 AT 7:02 AM
