since then I have tried to diagnose the problem to no avail. Replacing fuel pump, fuel filter distributor cap, rotor, plugs, wires, have done a compression test, replaced timing belt, and engine is timed properly, all relays and fuses are good.
so far what i've been able to diagnose is that the engine has low compression, 75psi in cylinder 4 and 1, 2, 3 are pushing only 72 psi, prior to the car dying on me it had good compression. Also as a result of the poor compression, the fuel pump is not initiating as a result of a loss of air flow through the air intake.
please help, I am supposed to be moving in 2 weeks and must have my car to do so.
SPONSORED LINKS
Friday, October 1st, 2010 AT 11:39 PM
