1986 Toyota Camry My car don't start
JOELG16
  • 1986 TOYOTA CAMRY
Electrical problem
1986 Toyota Camry 4 cyl Front Wheel Drive Automatic
Reasently my camry did't start a mechanic toll me that the problem was the ignition distribuitor and a replace it but steel did't start. I use a power tester and I notice that there is no power in the hot wire of the ignition distribuitor.
Any idea? I already check the fuses and relays
Tuesday, September 15th, 2009 AT 4:34 PM
Do below and comeback with some results
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Tuesday, September 15th, 2009 AT 4:47 PM
JOELG16
I already replace the ignition module and it start again.
Wednesday, September 16th, 2009 AT 4:21 PM
