1993 Toyota 4Runner will not start
FLOOPRIGGER12
  • 1993 TOYOTA 4RUNNER
  • 6 CYL
  • 4WD
  • MANUAL
  • 200,000 MILES
While driving, acted like came out of gear. Engine died. Now will not start. Acts like it is not firing/ turning over.
Friday, July 17th, 2009 AT 2:58 PM
Do below to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Saturday, July 18th, 2009 AT 6:25 AM
