Starts and then shuts off after 2000 RPM
GE'Z
  • 1999 HONDA ACCORD
  • 2.3L
  • 4 CYL
  • 350,000 MILES
My car starts and will stay on idling, but if I push the gas pedal to 2000 rpm and lLet It go it shuts off, like it was not getting gas or not enough power. I noticed that my O2 sensor downstream is not connected. I changed my oil pump alternator and O2 sensor upstream is new.
Tuesday, January 17th, 2017 AT 2:44 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,702 POSTS
Hey GE'Z,
There are a couple things that can cause this, vacuum leak, throttle bore service or an intake boot that is cracked. I will give you some guides for you to do to see if you can find the problem.
https://www.2carpros.com/articles/replace-an-air-intake-boot
and
and
Please run some tests and get back to us.
Best, Ken
Sunday, February 19th, 2017 AT 2:32 PM
Related Engine Stall While Driving Content
