Hello Joe,
I finally had to drive to Melton Ram to get the work order receipts for the last bit of work done to my truck, Remote Start / A/C / HVAC.
10/27/2021 MELTON, Andrew
Gave me three work order receipts. The top one states the customer’s concern of Remote Start and the HVAC not going on at the previous setting. The other two pages are dialog between Melton Tech Jim and “STAR” Agent Joey R.
Joey’s response is “James, the HVAC controller will not turn on or display activity until the bus is awakened by customer input. This can be opening the door or turning the key on, depending on the platform. The system is designed to run in the background based on set inputs when remote start is activated. We use software outside of the HVAC controller when using the comfort system. This does not indicate the system is not functioning properly.
Jim responds that he tested two 2020 Bighorns that worked at HVAC previous settings.
Joey asked Jim if he would test 2021 Bighorns?
Jim stated “I did test two 2021 trucks and was GUESSING a change in that model year, two other 2021, do the exact same as the customers truck.
Joey R. States “Understood. Looks like that’s just how the vehicle operates. Will go ahead and close the case. Thank you for your efforts and cooperation. Have a great rest of your week. Joey R. 10/19/2021 14:58:52
I told Andrew of Melton Ram, I seems to me they are using words “guessing and looks like” instead of what you told me. You told me about the Engineers at STAR, said it “was” the change in model year to achieve better efficiency. Andrew said yeah, that is what they were saying. 10/27/2021
SPONSORED LINKS
Wednesday, October 27th, 2021 AT 3:08 PM
