Hello, check for a battery drain, if it is excessive, start pulling fuses, one at a time, when you pull the fuse on the problem circuit, the drain will not be excessive. You can also check for lites that may be staying on, interior--glove box-- in the trunk--under the hood. Dark thirty is the best time to check.
A new alternator doesn't mean the charging system is working ok? Maybe a problem with a wiring circuit?
SPONSORED LINKS
Thursday, August 20th, 2009 AT 2:58 PM
