Start with the free stuff.
Remove the ignition module and have it tested at any autoparts store, have it tested at least twice so as to build up heat in module to simulate heat in engine compartment.
While your there, also have charging system tested, alt. battery, starter and any "drains" on system (also free).
Have them also check for any PCM errors (even though check engine light is not on) there may be pending codes ( this is also free).
Free is good :) .
SPONSORED LINKS
Sunday, August 30th, 2009 AT 8:04 AM
