1995 Pontiac Grand Prix
SILVER10
  • 1995 PONTIAC GRAND PRIX
Engine Performance problem
1995 Pontiac Grand Prix 140000 miles
I am curious why after driving a distance that the car will not start again right away.
Friday, June 4th, 2010 AT 7:28 PM
SATURNTECH9
  • 30,869 POSTS
When the car won't start does it crank no start or is it no crank no start?Also how does it not start for?Do you have any code's?Let me know.
Friday, June 4th, 2010 AT 8:08 PM
SILVER10
  • 9 POSTS
It does turn over and wants to start and if you can get it running it will go, but if not then it has to sit for 45 minutes to an hour.
Thank You for any suggestions
Saturday, June 5th, 2010 AT 1:11 PM
SATURNTECH9
  • 30,869 POSTS
Let's do this before we start putting parts in the car. On the Let's do this on the drivers side
bottom of the dash there's the obd1 connector where you would put a code reader on. Look at the top row of it far right side there's two pins side by side. Turn the key to the run postion don't start it and jump those two pins together and leave it that way. Watch the service engine soon light flash. You will see it flash once then two faster flash's. That's a code 12 that means the computer is good it will do this 3 times if it repeats the code 12 after the 3 times you don't have any codes. But watch the light for example if u see 3 quick flash's then 2 quick one's that would be a code 32 it would repeat 3 times then go to the next code when it gets back to code 12 then the code's are done. Let me know what you find and we will go from there. Also what size engine do you have?Let me know.
Saturday, June 5th, 2010 AT 2:23 PM
