2003 Pontiac Grand Am starting
KIRSTIEDOTSON89
  • 2003 PONTIAC GRAND AM
Engine Performance problem
2003 Pontiac Grand Am 6 cyl Automatic 125000 miles
A few weeks ago my car wouldn't start and both the battery and alternator were checked and said to be good. I jumped the starter and it started right up. Days ago, it wouldn't start again and I have been having the same problem but the car can now be jumped by the battery. Any ideas?
Monday, March 29th, 2010 AT 6:45 PM
Pick your symptom:
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Monday, March 29th, 2010 AT 9:58 PM
