HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Grand Am
Engine
Symptoms
Not Running
SPONSORED LINKS
2002 Pontiac Grand Am I ran out of gas!
JAY_DUB_44
MEMBER
2002 PONTIAC GRAND AM
6 CYL
2WD
AUTOMATIC
116,600 MILES
I ran out of gas. I put more gas (quarter tank) and it still wont start. Any sugestions?
Tuesday, August 25th, 2009 AT 1:36 PM
DOCFIXIT
MECHANIC
Suspect fuel pump picked up debris and overheated due to low fuel.
SPONSORED LINKS
Thursday, July 30th, 2020 AT 2:15 PM
MMPRINCE4000
MECHANIC
Excellent advice by Doc.
Gasoline keeps the fuel pump "cool" and running it out of gas will cause it to overheat and fail.
If bad pump, keep gasoline in tank at least 1/4 full to prevent future problems.
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Engine Turns Over But Wont Start?
Engine Mechanical Problem 2002 Pontiac Grand Am 4 Cyl Two Wheel Drive Automatic Car Turns Over Wont Start Replaced Alot Of Stuff From...
Asked by
ts_cracker
2002
PONTIAC GRAND AM
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Car Will Not Start
Car Will Not Start, Car Tried To Turn Over Several Times But Would Not Start, Dash And Everything Lit Up, Battery Slowly Drained. Tried...
Asked by
chernise
1 ANSWER
2002
PONTIAC GRAND AM
2002 Pontiac Grand Am Car Will Not Start Unless Check...
I Have A Pontiac Grand Am Gt, Which As Close To 108000 Miles On It. Since I Have Had It I Have Replaced The Starter And Battery Recently...
Asked by
chagness
1 ANSWER
2002
PONTIAC GRAND AM
2002 Pontiac Grand Am Starting And Stalling Issues
My Car Has Issues Starting And Stalling. I Have Changed The Fuel Pump, The Camshaft Sensor, And The Crank Shaft Positioning Sensor. Once...
Asked by
mpfuller
2002
PONTIAC GRAND AM
Car Wont Start
I Noticed My Low Coolant Light Was On Before Heading To Work. I Stupidly Ignored It Thinking I Would Be Okay To Make It To Work Thirteen...
Asked by
Correana Morin
3 IMAGES
2002
PONTIAC GRAND AM
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
