Before changing pump, change fuel filter and check the fuel pressure regulator.
OEM is best, but if they have the same warranty?
It's your money, but many shops use aftermarket pumps with good success. What problems are you speaking of with regard to aftermarket pumps.
If you do go aftermarket, get a direct fit, not universal.
SPONSORED LINKS
Sunday, June 28th, 2009 AT 7:07 AM
