1994 Pontiac Firebird 94 Firebird cranks but wont start?
SARAH1976
  • 1994 PONTIAC FIREBIRD
  • 6 CYL
  • 131,000 MILES
I just bought a 94 Firebird 3 days ago for 17 yr old son. Drove home no problems, our son went to go to work and it sounded like it was out of gas! Had a full tank. It turns over but wont stay started. I need help Please! Fiance thinks it is the fuel pump reset switch? Where is it located? Is there a reset switch?
Thank U
Sarah
Wednesday, August 25th, 2010 AT 6:28 PM
There's no reset switch-Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/COP/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Wednesday, August 25th, 2010 AT 7:04 PM
