1998 Pontiac Bonneville slow acceleration
SLIM23
  • 1998 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 172,689 MILES
When I press on the gas peddle to go, it takes a while for the car to pick up speed. I had the transmission checked and the guy told me that there was an electrical problem because the transmission wasn't getting the power it needed and was giving a flase reading when he checked it. I also got an oil change and had my battery checked and they gave me a slip that said my battery was good but it was low on charge. The slip said to check the alternator belt, charging system, and cables and connections. I had everything checked except the charging system. What could it be? What is the Charging System?
Sunday, May 4th, 2008 AT 4:40 PM
MASTERTECHTIM
  • 4,749 POSTS
It sounds like the transmission is stuck in failsafe mode and it is starting off in second gear. You will have to take it to a transmission repair shop and have them scan it and find out if its a transmission electrical problem or internal trans problem
Sunday, May 4th, 2008 AT 4:42 PM
