1998 Plymouth Voyager
ZK
  • 1998 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 111,000 MILES
I already send you a massage about my 1998 plymouth voyager but I did not get any answer so please send my answer I been waiting for it about 4 day's thank you
Friday, August 13th, 2010 AT 8:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Sorry we get many, many questions every day and we can only guarantee a response within 24 hours for the ones who donate.
Since you caught my attention though, what is the problem you are needing help with on your Voyager?
Friday, August 13th, 2010 AT 8:45 PM
ZK
My 98 voyager some time check engine light will come's on and car will gerk or want's to die and some time the cluster odomeeter and rpm and all gages will stop working can you tell me what's wrong with it and what I can do. Thank you.
Sunday, August 15th, 2010 AT 8:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Does the engine only jerk and stall out when the engine light comes on? If so then there is a sensor that is starting to fail and unfotunately until it fails completely would be extremely hard to point out which one it is exactly. As for the gauges, if all the gauges stop at once then there may be loose wiring at the back of the cluster assembly or the cluster itself could be bad.
Sunday, August 15th, 2010 AT 11:38 PM
ZK
I notes that any time ABS light come's on and stay's on then my van gages will not work I check it with obd11 and it gave me the code P1698 so can you please tell me what can do. Thank you very much.
Wednesday, August 18th, 2010 AT 7:17 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You more than likely have the common problem of these minivans- old circuits behind the instrument cluster. They start to get brittle and crack. You will have to remove the instrument panel and inspect for fine cracks or crappy solder connections- it may take some time to find.
The code you have lets the technician know there is a break in communication between the computer and one or more sensors (faulty connection). The most common location on these vans for a faulty connection is the instrument panel
Wednesday, August 18th, 2010 AT 8:30 PM
Related General Content
