2002 Oldsmobile Alero wont start
MIKENIESEN09
  • 2002 OLDSMOBILE ALERO
  • 4 CYL
  • 100,000 MILES
I got up this morning and started my car without a problem. Then about two hours later I tried to start it again with no sucess the first two times. The third time it started and I drove off. About a half a mile down the road it cuts out on me and starts to buzz at me while i'm stopped at a stop sign. The buzzing stopped and I cranked the car up again without a problem. I drive to work without it shutting off again. Then when I go to leave it wont start. Ive checked fluid levels, fuses, and the battery. Do you have any ideas as to what might be causing it? My radiator overflow was empty when I checked it and their was no fluid in the hose that connected to the engine.
Thursday, April 1st, 2010 AT 3:18 PM
TWOSTEPPER
  • 42 POSTS
I'd start by adding coolant. If it cranks good, but won't start, have a helper crank it, while you visually check for spark at the plugs. If that is ok, use a gage and check fuel pressure. Got to start somewhere, might as well start with the basics.
If your losing a lot of coolant, you need to find out, why.
Thursday, April 1st, 2010 AT 4:22 PM
