2002 Oldsmobile Alero Engine wont start
HOLEINHEAD
  • 2002 OLDSMOBILE ALERO
2002 Oldsmobile Alero 6 cyl Two Wheel Drive Automatic
engine turns over but car wont start. Is fuel pump located in gas tank or elsewhere. Can spray into inlet fuel port and car will start but dies out.
Thursday, September 10th, 2009 AT 11:03 AM
  • 109,758 POSTS
It sounds like the fuel pump is bad. Have you checked the fuel pressure? Here is the "HOW TO" for checking the pressure. Let me know what you find. Also, if you need the gauge, most parts stores will lend or rent them.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
To answer the other question, the fuel pump is in the tank. However, you could even have a plugged fuel filter.
Friday, September 11th, 2009 AT 11:29 PM
