1998 Nissan Sentra No start
8STANG6
  • 1998 NISSAN SENTRA
  • 4 CYL
  • 150,000 MILES
Ok I have put a scanner on the car and I had o2 sensor and cam sensor codes and I cleared both thinking if the cam sensor is bad it would come back up when crankin engine over again now I have no codes and engine still will not start I have spark and fuel pump kicks on no how do I check the cam sensor and where is it. Are these cars known for any common problems with no start it cranks just fine sounds like it wants to fire then nothing
Tuesday, February 5th, 2008 AT 8:33 PM
BMRFIXIT
  • 19,053 POSTS
Check timing
disconnect the cam sensor try to start
it may crank a bit to start
Tuesday, February 5th, 2008 AT 10:05 PM
8STANG6
The cam sensor I was told was built in the distributer so I bought a new dist and it still wont start no check engine lights nothin im lost it gets spark and fuel pump kicks on
Wednesday, February 6th, 2008 AT 6:20 PM
BMRFIXIT
  • 19,053 POSTS
You need to check if you have power at the coil
check/replace crank sensor
Wednesday, February 6th, 2008 AT 8:37 PM
