1996 Nissan Sentra wont start
TCLARK3585
  • 1996 NISSAN SENTRA
Engine Mechanical problem
1996 Nissan Sentra 4 cyl Front Wheel Drive Automatic
ok I broke my serpiten belt and when I replaced it and tryed to start my car it would try and turn over but it will not I was wondering if anyone knew why that was and if so how to fix it I checked all the usual suspects to see if that was the problem but still didnt start
Tuesday, February 24th, 2009 AT 7:53 PM
ZACKMAN
  • 4,202 POSTS
Usual suspect is that you need to make sure:
1. Check your fuel pressure at the fuel rail, must be around 45 psi.
2. Check for spark. Use #1 spark plug, must be blue minimum of 1"
And then follow this diagnostic.
HARD START/WILL NOT START
Check battery and starter.
Check fuel pressure.
Check fuel pump circuit.
Check fuel pressure regulator.
Check fuel injector circuit.
Check fuel evaporative emission circuit.
Check Idle Air Control Valve-Auxiliary Air Control (IACV-AAC) valve.
Check ignition timing and ignition circuit.
Check timing chains.
Check Exhaust Gas Recirculation (EGR) valve.
Check Positive Crankcase Ventilation (PCV) system.
Check Camshaft Position (CMP) sensor circuit.
Check Mass Airflow (MAF) sensor circuit.
Check Engine Coolant Temperature (ECT) sensor circuit.
Check main power supply and ground circuits.
Wednesday, February 25th, 2009 AT 2:10 AM
TCLARK3585
Thank you for reply I will be checking this weekend when I have time off work
Thursday, February 26th, 2009 AT 3:56 PM
ZACKMAN
  • 4,202 POSTS
Let me know what you find out.
Thursday, February 26th, 2009 AT 8:12 PM
