Hi OURCHILD09 and TY for the donation
Do a fuel pessure check, the specs calls for 36psi
See below:
FUEL PRESSURE CHECK
When reconnecting fuel line, always use new clamps.
Make sure that clamp screw does not contact adjacent parts.
Use a torque driver to tighten clamps.
Use Pressure Gauge to check fuel pressure.
Do not perform fuel pressure check with system operating. Fuel pressure gauge may indicate false readings
Release fuel pressure to zero.
Disconnect fuel hose between fuel filter and fuel tube (engine side).
Install pressure gauge between fuel filter and fuel tube.
Start engine and check for fuel leakage.
Read the indication of fuel pressure gauge.
At idling:
With vacuum hose connected:
Approximately 235 kPa (2.4 kg/cm2 34 psi)
With vacuum hose disconnected:
Approximately 294 kPa (3.0 kglcm2, 43 psi)
If results are unsatisfactory, perform Fuel Pressure Regulator Check.
SPONSORED LINKS
Monday, November 30th, 2009 AT 6:12 PM
