1992 Nissan Sentra help wont start
LOWEREDEFFECTS
  • 1992 NISSAN SENTRA
  • 4 CYL
  • FWD
  • MANUAL
  • 34,000 MILES
I was on the highway going 95 in 3rd and went to shift into 4rth an it went into 2nd gear an all I heard was grinding an now it wont start please help
Wednesday, April 16th, 2008 AT 10:05 PM
DISCOSTU24000
  • 37 POSTS
Yikes, you may have bent your valves, by over-revving the engine. Did the RPM gauge go into the red? If so then you'll probably need a valve job. Do a compression test first. If you've got no compression then take it to a mechanic that does major engine work.
Wednesday, April 23rd, 2008 AT 1:27 PM
