Thanks for the recent responses.
***The car has had ty rods replaced because they were bent. (Are ty or tie rods same as sway bar?)
*** front end was aligned because it was pushing forward
*** struts were good.
You mention sway bar and stabilizer links.
Where is the sway bar(is this the same as stabilization bar) located?
Also, are the bushings and links the same and attached to sway bar? Give me some locations for these parts. Need defining of parts that we speak about.
If bar and bushings are fine, what else could it be?
In addition, steering is loose---should I look into something that has to do with steering causing the car to be unsteady?
My concern is when driving and road pitches or level changes, car feels like it will tip and unstable.
Saturday, September 20th, 2008 AT 6:43 PM
