1997 Nissan Pathfinder Non-Starting Engine
PILGRIMHLL
  • 1997 NISSAN PATHFINDER
  • 6 CYL
  • 232,000 MILES
I Change the gasket on my intakemanifold and now my car won't start unless I keep turning the distributor cap. Anyone very have this problem?
Monday, October 6th, 2008 AT 8:48 AM
KERENSELF
  • 54 POSTS
If you have to rotate the cap to get it to start, sounds like your timing is off a few degrees. Did you remove the distributor when you changed the gasket? If so, the gear may not be aligned properly with the camshaft.
There could also be contact problems. I would take off the cap and check to make sure there are no cracks in the cap or rotor and no corrosion on the contact points.
Sunday, October 12th, 2008 AT 10:10 PM
