1999 Nissan Maxima no start
PREOWNEDDEPT
  • 1999 NISSAN MAXIMA
Engine Mechanical problem
1999 Nissan Maxima 6 cyl Front Wheel Drive Automatic
car cranks well and has spark, if I spray fuel in throttle body car will run, and I have fuel up through the filter
still no start. Which sensor operates the injectors?
Thursday, April 2nd, 2009 AT 8:39 PM
Check the fuel pressure and also if the injectors are pulsing. If its not pulsing and has power to the injectors the ground drivers circuit of the computer is defective
Might also be that the computer is not getting an ignition reference signal to pulse the injectors
Thursday, April 2nd, 2009 AT 8:43 PM
PREOWNEDDEPT
Does the cam sensor reference the signal to injectors?
Monday, April 6th, 2009 AT 6:50 AM
Some manufactures uses the CMH sensor to synchronize the injectors
Monday, April 6th, 2009 AT 12:00 PM
PREOWNEDDEPT
Is it the same pulse to the ecm and the ecm sends return signal to both injectors and coil?
Also how common does a ecm go bad
Tuesday, April 7th, 2009 AT 9:00 AM
PREOWNEDDEPT
The car has ignition coil pulse just not injector pulse is? Is it the same pulse to the ecm and the ecm sends return signal to both injectors and coil?
Tuesday, April 7th, 2009 AT 9:02 AM
Do you have power to the injectors?
Tuesday, April 7th, 2009 AT 3:21 PM
