Do this before you crank the engine over-In a spray bottle with gas in it-spray into the throttle body. Did it fire up instantly? If not could be lacking ignition spark continue to troubleshoot the ignition system if it has spark, check the fuel pressure to rule out a failing fuel pump.
SPONSORED LINKS
Thursday, May 28th, 2009 AT 4:58 PM
