I have starting problems with my 96 Maxima SE (manual trans) since last year and its getting worse (or may gets worse in summer). But sometimes it wont start. Cranks fine but wont pick up. Replaced fuel filter and fuel regulator and use fuel cleaners but problem persists. When it wont start, I tend to press the pedal a couple of times and when it starts (after many cranks), it is in a hesitation mode for about a minute so I have to keep it reveved high. I can also smell gas when it starts but thats probably due to me pressing the gas pedal. By the way, the car starts normally most of the time on first crank and always starts fine while I am out. Only has a starting problem after standing for a long time or overnight. I also think the problem happens at times when the car is tilted backwards rather than on a slope with the front facing down.
Once it is running, no problems. Only a couple of times, I felt the engine stopped during first minute or two of running out of a bad start and since car is in motion, it picks up again. But otherwise, it runs just fine. Also, when it wont start for a long time, I had people push it and starts right away.
Funny thing is, the starting problem has happened at exactly the same spot many times.
Pls. Help.
SPONSORED LINKS
Tuesday, July 6th, 2010 AT 2:56 PM
