Dimming of lite indicates the battery is NOT fully charged and/or alternator not charging the battery. How did yu check the battery? Did you do a load test?
I suggest that you charge the battery fully and check the battery terminal connections. If the car then cranks at normal speed and starts, that could be your problem. Furthermore, once the engine is running, check the battery voltage when the engine is at idle speed. It should read about 13.8 volts. If it reads at 12 volts, then your alternator is bad.
SPONSORED LINKS
Friday, April 16th, 2010 AT 8:46 PM
