Heat only works at higher speed
NOWCAT
  • 2003 NISSAN ALTIMA
  • 2.0L
  • 4 CYL
  • 125,000 MILES
Hot air only comes on at higher speed.
I just had the thermostat replaced and it did not fix the problem.
Thursday, January 4th, 2018 AT 9:00 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Is it that it is not hot or that the blower only works on high, because if the blower only works on high, chances are it is a faulty resistor because high speed does not go through that resistor but speeds 1, 2 and 3 do.
That resistor is located under the right side of the dash.
Friday, January 5th, 2018 AT 1:53 PM
Related General Content
