1999 Mazda 626 after driving and turning off, won't restart
CARLOS G
  • 1999 MAZDA 626
  • 4 CYL
  • FWD
  • 132,000 MILES
I'm having a problem with car not restarting after driving somewhere and turning off. After waiting, sometimes as 15 min. Or up to a few hrs. It will resart.
Saturday, March 28th, 2009 AT 9:37 PM
Don't wait for 15 mins-Do below immediately to determine if its a fuel or spark problem
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, March 29th, 2009 AT 7:02 AM
SWANEPGA
Sounds to me like a tyical crankshaft position sensor problem
Saturday, April 4th, 2009 AT 3:13 AM
