1995 Jeep Cherokee Electric Fan
JONSIMS
  • 1995 JEEP CHEROKEE
Engine Cooling problem
1995 Jeep Cherokee 6 cyl Automatic
My engine electric fan keeps working after the engine has been turned off. Have to disconnect to stop fan running and then reconnect when engine has cooled down.
Friday, April 17th, 2009 AT 6:35 AM
SCOTTM2_99
  • 6 POSTS
I just fixed the same problem on my jeep by replacing the fan relay in the engine comparmtn. My is a 1998 and the relay is located beside the battery in a fuse box--assume yours would be in the same place. It cost $10 from advance auto. There are four relays in the box (fan, asd, fuel and a/c.) Make sure you look at the label correclty so you know which relay it is.I repalced the wrong one initialy.
Thursday, April 30th, 2009 AT 8:05 PM
