Engine Cooling problem
1994 Jeep Cherokee 4 cyl Manual
Just Now I change the temperature sensor, temperature sending unit, thermostat, radiator and water pump but the temperature meter also height over 100. What must I do?
Saturday, July 31st, 2010 AT 12:53 PM
MECHANIC
Pressure cap ok? Are you loosing coolant? Cooling fan is drawing air? Test coolant temp with a digital thermometer to see what the core temp is, it may be a gauge problem if the coolant is not actually at the indicated temp, start here.
