2003 Hyundai Accent check engine light
MANMAC
  • 2003 HYUNDAI ACCENT
Engine Performance problem
2003 Hyundai Accent 4 cyl Two Wheel Drive Manual 60m miles
when I push on gas some times it feels like something is holding it back then it picks up and goes great, I had an old code for o2 sensor and a new code for a tps sensor. Also had a bad exhaust, changed the exhaust put in a new tps sensor, car still slugish now and then.
Tuesday, November 25th, 2008 AT 8:59 AM
KHLOW2008
  • 41,814 POSTS
Hi manmac,
Is the CEL still showing?
When replacing the TPS, was it properly calibrated?
Did you check the spark plugs and related parts for the hesitation?
Did you replace the O2 sensor?
Sunday, November 30th, 2008 AT 8:56 AM
