The mechanics can't find out why it is stalling. I will be going down the road or freeway and it will quit working. Sometimes it won't start on the first try of the day. It seems to be worse when it is low on fuel. When I try to start it after it stalls the RPM will rev up then fall back down it will do that several times then finally start.
SPONSORED LINKS
Thursday, February 11th, 2010 AT 2:51 PM
MECHANIC
Have your fuel pressure checked if okay get these components checked and tested-crankshaft position sensor, coolant temperature sensor, idle air control valve and throttle position sensor
