when the throttle is suddenly snapped open the engine drops off to 500rpm with full open throttle. The engine will not cut out but stays at the 500rpm until the throttle is closed. If the throttle is opened slowly the engine will respond asd normal. Have you came across this problem before or can you give me any advice on what I should try?
SPONSORED LINKS
Wednesday, January 28th, 2009 AT 3:26 AM
