I don't know what tests were performed by your mechanic, but it's possible you need a new computer.
The way to check for a bad computer is to check reference voltages at your sensors. If one/more of your sensors isn't recieving the correct voltage, and it isn't a fault in the wiring harness/connector, then the computer is bad. Also, if the injectors aren't recieving a pulse, or the pulse isn't within spec (no wiring/connector problems), then your computer is bad. Same thing for the other outputs. But you need to measure these circuits and have the specs to compare them to.
SPONSORED LINKS
Thursday, February 25th, 2010 AT 8:42 AM
