2003 Honda Accord
GARYK11
  • 2003 HONDA ACCORD
  • 6 CYL
  • FWD
  • 75,000 MILES
Check engine light came on. Check with meter, code P0497, "Evap emission low purge flow fault" Not sure what part to look at or where. Can you be of help?
Thanks.
g
Saturday, February 6th, 2010 AT 3:26 PM
KHLOW2008
  • 41,814 POSTS
Hi garyk11,
Thank you for the donation.
The most common cause of this DTC is a loose gas cap.
DTC P0497: EVAP SYSTEM LOW PURGE FLOW
Check if the fuel fill cap is installed and properly tightened.
- Properly install the fuel fill cap (the cap must say "Tighten to click"). If should turn 1/4 turn ( t least 3 clicks must be heard) after it's tight, reset the PCM and retest.
It might come on and require some running time before it goes away.
If the above does not resolve the problem, we would have to go into diagnostics, let me know if it is necessary.
Saturday, February 6th, 2010 AT 10:28 PM
